How do I progromatically change page focus on a tab control?
I would like to progromatically change which page on a tab control is in focus. I have tried looking into the tab properties and the individual page properties but have not found the proper property to modify.
(3,364 Views)
Change the value of the tab...e.g. by writing the wanted page index to a local of the tab control.
(3,364 Views)
...make sure the tab is an indicator, not a control 🙂
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,364 Views)
Why?
The method is just as applicable with the tab as a control.
(3,364 Views)
Thanks to all. That had been my first guess and I thought I had tried that ... but I guess I didn't.
(3,364 Views)
If you change the tab control to an indicator you can create a property node using the value property and write to it that way. Hope this help. Otherwise as a control just write to the terminal.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,364 Views)
Sorry - I had misread your answer. You're right: it can be anything if you're going to use locals or property nodes, but it needs to be an indicator if you're going to write directly to the node istelf.
(3,364 Views)
