How do I put a fixed scale of 1 Minute Intervals on the X-axis of a Wavform Graph?
Hello
I am using a Waveform Graph and I would like to put a set of 1 minute real time intervals on my graph.
My data comes once every 4 seconds, so the 1minute intervals  must be in real time with my incoming data.
So about every 15th data point, I should cross a 1minute marker.
but can anyone tell me how to create these 1 min intervals that would be real time with my incoming data?
thanks
J
Message 1 of 11
(4,155 Views)
I suspect that you should be using a chart instead of a graph. To display time on the x axis, why don't you give the shipping example called Real-Time Chart a look. With a few quick mods, it would look like the image below.
Message Edited by Dennis Knutson on 10-13-2009 02:06 PM
Message 2 of 11
(4,152 Views)
hello
Im new to Labview, I have tried a Waveform Graph and also Chart.
I have also tried to real time example, but it charts to the second.
How do i just chart to the minute?
J
Message 3 of 11
(4,147 Views)
If you have used the example and can't get it to work, post what you've done. The only modification I made to the example was to set the Offset to 0, maximum to 240 to get a 4 min scale, set the delay to match yours, and turned on the gridlines.
Message 4 of 11
(4,145 Views)
I cant get the X scale intervals to stay fixed...each time I start my application, the scale moves ??
How can I always get a a fixed set of 1minute intervals?
thanks
J
Message 5 of 11
(4,141 Views)
Change the formatting back to relative time and use 0 as the offset (as I said) if you want the time to start at 00:00:00.
Message 6 of 11
(4,136 Views)
I would like to start at the same time as the windows PC clock  (hh:mm)
Then starting at that time, I would like to have set 1min intervals  ,e.g  if start was   4:40pm....then I would like to set 4:41pm  4:42pm, 4:43pm, 4:44pm etc as my 1min intervals on the X axis
Can you help with this ?
J
Message 7 of 11
(4,133 Views)
Since you start at random times, I suspect you will have to turn off uniform marker spacing and create an array of marker spacings and write it to the MarkerVals[] property node. See attached
Message 8 of 11
(4,130 Views)
this is the closest solution i've seen....the only thing is, this test will run for months.
If I follow you correctly, I would have to create a huge array of marker spacings (marker vals)??
Would these spacing continue as the graph advances to the end?
J
Message 9 of 11
(4,127 Views)
No, I don't think the intervals will continue. You may have to use uniform markers. Right now, I don't know if you can get all markers uniformly spaced if you use system time and start at some random moment.
Message 10 of 11
(4,120 Views)
