How do I read a Load Cell using SCXI 1121 Card?
I have a 5000 lb load cell and I am using a SCXI 1121 to read it. I have attached a calibration sheet for the load cell. I need to know what to set the gain to and how to convert the MV/V reading to Lbs. I want my channel in Max to do this conversion.
(2,869 Views)
I'm not familiar with your card, but you should be able to leave the gain setting at 1. Read the mV/V output from the cell and multiply it by 2304.0 (5000/2.1701) to get pounds. You can use this value in max under linear scale with a zero offset.
(2,856 Views)
