‎08-22-2008 10:13 AM
I have a computer with the DSC module installed and is logging data into the Citadel databae on that machine. Periodically I copy the raw data over to a
separate network drive for backup. I delete the original copy to save space. I have an engineer who wants to analyze the data, but does not have LabVIEW installed on his Windows XP 64-bit machine. What is needed to allow him to view the data.
‎08-25-2008
03:03 PM
- last edited on
‎09-27-2026
02:53 PM
by
Content Cleaner
Dan,
In order to analyze the data, they will need LabVIEW DSC Run-Time to access the Citadel 5 ODBC driver. They will then be able to view the contents of the files through using SQL queries.
Please see the following KB: Retrieving Data from a Citadel Database Without Lookout or the LabVIEW DSC Module Installed [link removed; article no longer available] for more information.
‎08-25-2008 03:17 PM
Hello Jared_B,
Thank you for your response to my question. Will the DSC Run-Time install on a 64-bit OS? I could not find one that listed Windows XP Pro 64-bit.
‎08-26-2008
11:05 AM
- last edited on
‎09-27-2026
02:54 PM
by
Content Cleaner
Dan,
Woops! Sorry I didn't even notice that in your first post. Currently, National Instruments Application Software (ie - LabVIEW) is not supported on Windows XP x64.
‎08-26-2008 02:00 PM
Jared,
Nothing to worry about. Thank you for the information and confirmation on the Windows XP x64 not being supported.
