How do I read elements in four arrays and store in variables?
Greetings,
I have 4 arrays that I will read to control an autonomous robot vehicle as instructions.
I need to be able to read the first elements in each array and store in 4 separate variables (direction, speed, angle, distance). Then wait until that first instruction has been executed. Then I move on to the second elements in each array. I will repeat this until I have gone through all the elements. I am struggling to figure out how to do this?
Please note:
-The number of elements in the arrays are always the same, although the number of elements vary because the can be less instructions or more.
For example a complete instruction takes 1st element from array 1, array 2, array 3 and array 4 and this builds up something like: Forward, 10, 20, Left. This then will result in the robot moving Forward at a speed of 10 for a distance of 20 and then make a left turn. Once thats done then it takes the  2nd elements and so on.
Please find attached my VI that reads a text file and creates the 4 arrays.
Thank you.
(4,145 Views)
Hi Stan,
Well, right now you read a 2D array and get it's first 4 columns in seperate indicators…
LabVIEW doesn't use "variables" in the same way as text-based programming languages, values are stored in wires and shift registers. When you have problems understanding this you should take the (free) beginner courses offered by NI…
Learn about using "auto indexing" with loops. It will make your live easier - and solve your current problem too!
(4,123 Views)
Hi GerdW,
Firstly, I would like to thank you for your time replying to me.
Unfortunately, I don't think you understood my question.
Kind regards,
(4,115 Views)
Hi Stan,
I think I understood your question very well.
I even think I gave you the correct answer.
When you still think, that's not the case: Explain your problem with more details and examples…
(4,109 Views)
Accepted by topic author stanm13
stanm13 wrote:  Unfortunately, I don't think you understood my question.
Then I would say either a) you don't understand the answer or b) you did not explain it well enough.
To perform each element in an array, using a FOR loop with autoindexing inputs is the way to go.
(4,098 Views)
Thank GerdW.
I know where I was going wrong now.
Kind regards,
(4,085 Views)
Thank you crossrulz.
It was a mixture of both.
Kind regards,
(4,083 Views)
