How do I read multiple channels at one time using labview with the Fluke Hydra Data Bucket 2620a using serial port?
I need to take a reading of 15 channels about once a second. I can read one value at a time using the monitor function on the read values.vi driver, but this takes forever to read all the channels.
(3,031 Views)
I don't have this instrument but I took a look at the instrument driver and it appears that you can only configure one channel at a time to read from. You might want to take a look at the command set for this instrument and see if it allows for configuration of multiple channels. It could be that the instrument driver just doesn't have that built in.
J.R. Allen
(3,031 Views)
