How do I read one element from a 2D array
Hi. I have a series of images, each saved as a 2d array in txt files .
They have 525x525 elements.
Currently i have written a sub-vi that integrates all of the numbers for 2D array
However, now i would like to read the value of
a)1 element from each 2d array
b) And  in the future, a sub-set of elements (eg 10x10 array starting at (250,300)
I have up to 400 arrays at a a time. Any suggestions? Thanks
Andy
(3,337 Views)
The "Index Array" function under "Arrays" on the diagram palettes allows you to supply both row and column indices, returning a single element (using only one or the other returns a whole row or column) and the and "Array subset" can be used to extract subportions of a larger 2D array.
P.M.
Message Edited by LV_Pro on 10-04-2005 11:00 AM
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,334 Views)
