How do I read the VI Analyzer config file?
   How do I read the vi analuzer config file? I am getting alot of errors on the Front Panel Size and I do not know what the desired size should be. Where is the expected max size of the front panel specified?
Kaspar
(3,117 Views)
Accepted by topic author Kaspar
If you have VI Analyzer installed, you can load the configuration file and look at the Select Tests section. There is a test for Front Panel maximum size under Front Panel -> User Interface. The default is the current monitor resolution of the PC (including multiple monitors). You can change this to your desired setting.
(3,093 Views)
Works for me thanks
Kaspar
(3,065 Views)
