How do I read the current digital output?
Im using LV 7.1 to control a stepper motor (direction only) using user defined set points that are measured by a linear encoder.
Basically I want to make it bounce between two set points by switching the motor direction. I can do the outer bounds fine, but to tell LV which direction it should go in between I want to just have it look at the digital output that I am sending to the motor and just continue to send that same signal. I know that it is on port 7 line 0 of my card, I just haven't figured out yet how to grab that information. Any ideas?
Thanks.
(2,689 Views)
What boards are you using for this?
(2,650 Views)
