How do I read the duty cycle of a 1D Boolean array
I am trying to read a digital signal using one line of a PCI-6503. The input I want to capture will run at 1 Hz with a 50% duty cycle. Otherwise it will be either always on or always off. So I need to be able to tell if it goes into this flashing, from either steady on or steady off.
I have tried various ways of converting this signal to a digital wave and then to an analog, so I could use the Pulse Measurements vi that will tell me the duty cycle, but no luck. So I have thrown the whole thing away and am hollering for help.
Smiley Sad
(3,085 Views)
Accepted by topic author slipstick
A starting point:
(3,079 Views)
Ah, I bow to the superior math whiz. Smiley Happy
Excellent starting point!
(3,066 Views)
