Arek,
Thanks for answering. Yes, I have removed both 6.0 & 7.0 and reinstalled 6.0 only. I had an IT guy go through the registry and manually remove anything related to LV. The problem still occurs in the reinstalled 6.0. Internet Explorer's Help function is working normally. I negelected to tell you that I am running 6.0 under Windows XP. This problem may have always been there, but, I never noticed it until after I installed 7.0...All other LV 6.0 functions appear to work normally, but I haven't used every function yet...Is 6.0 compatible with XP? It would help if you can tell me what .hlp file is used, or what registry entry I should look for - then I could remove, repair, or replace it. This is one of those nagging problems that bother me and
I would like to fix it...Thanks again for your efforts!
