I have two sub-VI's - one that makes a laser distance measuring device turn on and return a distance, and another that moves a platform upon which a target is mounted that the laser reflects against. The laser VI takes well under 5 seconds to complet. The platform-moving VI, on the other hand, requires about 30 second. I would like to be able to have the laser on AS the platform moves. Of course, I can accomplish this by running the VIs seperately. However, I would like to control them from a master VI. Currently, the laser turns on as the platform begins to move but then turns off, since the master VI waits on the platform-moving VI to
complete. Any help with this seemingly simple dilemma would be greatly appreciated.
