How do I save a front panel object image with full color depth?
When I use the Invoke Node method to get the image of a front panel object, and then save it as a bmp or png, I seem to lose color depth. What do I need to do to programatically save front panel objects with the same color depth as they appear on the screen?
I'm using LabView 2011 11.0
(2,920 Views)
Accepted by topic author caleyjag
You have an input in that Invoke node called Image Depth.  You wired an 8 to it.  Why?  Wouldn't that mean you are capturing an image at a rather low image depth of only 8 bits?
(2,918 Views)
Ummm... maybe because of that 8, where you're specifying 8-bit depth?
(2,917 Views)
Yup, if I type 24 in there instead of 8 it solves the problem. 8 was the default value.
(2,905 Views)
