How do I save an image of a 3D Curve?
(2,501 Views)
Could you describe a little bit more what you want to do ?
If you have 3D graph on the front panel, make an "invoke node" on the front panel object (by right clicking >> create >> invoke node), the on the invoke node that will appear on the diagram, choose "get image" and link the image data to a "save to image" function.
You can find some code (luz.zip) that does something alike here.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,496 Views)
