How do I save on CD-RW programatically from LV5.11 on W2000?
Adaptec Easy Creator V4.01 is installed on my computer.
CD-RW is TEAC CD-W54EK
(3,159 Views)
If you use the DirectCD (it should be on your Adaptec CD) you will be able to do this. DirectCD is a program which runs in the backround and "mounts" your CD-RW as if it is a normal read-write drive. You can then read from it and write to it as if it were a hard drive.
-Jim
(3,159 Views)
Keep in mind that you have to close this drive with DirectCD when you are done if you wish to read this CD from another CD ROM drive.
(3,159 Views)
Thanks !
Now,...
How do I close the drive programmatically?
(3,159 Views)
You can close it on any computer with DirectCD installed on it. However you can read it on any computer with a CD-RW and DirectCD installed without closing it.
-Jim
(3,159 Views)
Thank you all for answering me BUT...
Maybe I should Refrase my question...
What I need my program to do is to produce when asked, a CD copy of all the data colleced, with a software that reads the data. This CD needs to be readalble from any other computer, with a regular CD-ROM.
Igor
p.s. Sooner or later I will have to find the solution for this problem... When this happens I promise to post it here
(3,159 Views)
