How do I select more then one channel to view in tdms file viewer graph panel
Here is the VI that has the errors:
Message 11 of 12
(528 Views)
@SteMob wrote:
It may not pull up errors on yours...
It doesn't.  I'd normally say to post your code showing the error, but it is my code.  The Get Channels list is from vi.lib and is unmodified.  It should output a 1D array, and so is the load and format values.
I'd suspect one of these two VIs have been modified by you in an attempt to get things working earlier.  Generally editing system VIs like these are a bad idea because you don't know who is calling them (like my posted code).
Message 12 of 12
(512 Views)
