How do I send a binary number to the RS-232 com port
How do I send four binary bytes to my Rs-232 port by LabVIEW? The format I need to send is:
byte 1 - Address low byte
byte 2 - Address high byte
byte 3 - On/Off byte (0-255)
byte 4 - Number of bytes to be transmitted.
(3,151 Views)
Depending on where your data is to start with, do 1A or 1B:
1A... Create a cluster with the data types you want in it. Pay attention to data representations - if you want a single byte, put a U8 in the cluster. I would guess your example would be four U8s. Pay attention to cluster order - they should be in transmission order.
1B... Use a BUNDLE function to assemble the data. Pay attention to data type - use conversions to U8 if necessary. If your address is a U16 or something, use the SPLIT function to make two U8s from it. Pay attention to the byte order.
2... Use a FLATTEN TO STRING function to convert the bundle (whether from a front panel cluster or a bundle) to a string.
3... Send the string out via the serial port SEND function.
Steve Bird
Culverson.com
LinkedIn
(3,151 Views)
Or build your data into an array of U8 then use the Byte Array to String function in the string functions > conversions palette...
(3,152 Views)
I am under the impression that the cluster introduces extra structure info when used in "Flatten to String". Basically, 4 (or any number) individual bytes is different from a cluster of 4 bytes. Please correct me if I am wrong.
-Joe
(3,151 Views)
Incorrect. The Cluster adds nothing to the flattened string - test it for yourself.
Four U8s in a cluster flattens out to a 4-byte string.
Steve Bird
Culverson.com
LinkedIn
(3,151 Views)
