How do I send an HTTP request to a web server using the TCP functions?
Jeff hi!
i need to do the exect same thing as you did. could you please send me your code?
Shai
Message 31 of 34
(3,091 Views)
Unfortunately, I was unable to get the Stunnel solution to work for me.  What I ended up going with was an ActiveX solution based on the example found in C:\Program Files\National Instruments\LabVIEW 2009\examples\comm\axevent.llb.  I modified (only slightly) the ActiveX Event Callback for IE.vi to get things to work.  I use the 'innerText' property of the 'body'.  Hope this helps.
Message 32 of 34
(3,073 Views)
For anyone's convenience and use.
A driver is atteched  Shai CohenR&D Engineer
Novamedes israel
Message 33 of 34
(2,998 Views)
Pretty much last gasp here - looking for ideas and thought this conversation was close to relevant. I am looking to post a file using similar vi's to those mentioned. I can post strings ok, but dont quite know the format of the file (more specifically how to encode it).
I have looked at base64 encoding and gzip, but when I post the file it gets corrupted. I have the headers and  multipart/form-data correct (as the file appears on the server).
Has any one here managed to HHTP post a file with Labview 8.2?
Thanks.
Message 34 of 34
(2,357 Views)
