How do I set a key focus that still allows me to tab to the next sequential control?
I have 3 string controls with a tab sequence of 1, 2, 3, and I want control 1 to get key focus when I start the VI. I want to enter text into it, then TAB to control 2 and enter text, then tab to control 3 and enter text. But the KEY FOCUS property set to TRUE on control 1 keeps me locked on control 1 and I can't tab out of it.
(3,150 Views)
Would you mind posting your program?  If you set Key Focus outside of your control loop (if you have one), you shouldn't have problem.
I've attached an example.
The "Text.Selection" property makes any value in the first string control highlighted when the VI is started, so that the first string control acts the same as the other two.  Remove it if you don't need it.
(3,143 Views)
The "Text.SelStart" property works better.
Updated VI attached.
(3,138 Views)
Thank you! I just needed to take my key focus property OUT of my loop.
(3,133 Views)
