How do I set file properties (win XP) ?
Does anyone know how to set/modify a windows file properties inside Labview ? For exemple : change the author, the comment... etc.
Thank you !
J.K.
(2,859 Views)
It is not possible with advanced file I/O LabVIEW VIs.
There is a possible workaround by using low level Windows functions in a dll.
Perhaps the easier would be to set your properties at the top of your file.
You will find some explanations here :
http://forums.ni.com/ni/board/message?board.id=170&message.id=85101&requireLogin=False
regards
Marc L.
NIF
(2,825 Views)
Thank you very much for your help !
( I should have found the link before to avoid repeating the question. )
J.K.
(2,821 Views)
