How do I set gragh dimensions for more than one graph in Labview 6i report generator (exel.)? First graph plots fine but cant set dimensions for second graph.
How do I set gragh dimensions for more than one graph in Labview 6i report generator (exel.)? First graph plots fine but can't set dimensions for second graph.
(2,306 Views)
Excel Update Graph VI allows you to select on which graph to perform the modifications. You should use the "graph index" input to select which Excel graph to update. Use this VI first, then some of the "set graph" VIs for each of the graphs you want to modify.
Zvezdana S.
(2,306 Views)
