How do I set key focus of a table cell?
Okay, I have figured out how to edit a table cell after setting a key focus.  Can anyone tell me how to write the contents of my table to a text file??  Please see the attached.  Thank you,
John
Message 11 of 13
(798 Views)
Try the "Items" property, which is a 2D array of all the strings in the multi-column list box (which is what you are using - a table is a different control).  You can use "Array to Spreadsheet String" with a format of "%s" and then write that string to a text file, or wire the Items array directly to Write to Spreadsheet File.
Message 12 of 13
(796 Views)
Thank you, that helped!  🙂
Message 13 of 13
(793 Views)
