How do I set the cal factor in a graph properties via a GUI
How do I set the cal factor under properties in a graph window to different values using a GUI interface; button, or selector?
(2,994 Views)
What do you mean by a "cal factor"?  Can you post a screenshot or VI showing this?
(2,993 Views)
Sorry about that, what I meant to say was "multiplier". I need two different multipliers at different times.
(2,990 Views)
Ok, think I figured it out. What I needed was a property node, set to write. Sound correct?
(2,988 Views)
That sounds correct.
(2,983 Views)
