How do I set the time axis on my waveform chart to show run time i.e each time i start the program i should have 0 as my starting point
How do I set the time axis on my waveform chart to show run time i.e each time i start the program i should have 0 as my starting point. I've been messing around with the without success. I'm running Labview 2012.
Thank you!
(3,643 Views)
In the Chart properties set the X-axis type to float. Then when you execute the code wire an empty array to the HistoryData property.
(3,638 Views)
I can't seem to figure out what you mean. I have no formal training with labview. It's taken me a long time to write the simple program I've attached. Any further guidance would be greatly appreciated!
(3,627 Views)
Accepted by topic author townes
Its pretty normal for a newbie taking time to write code. Right click the Waveform chart>Create> Property node>History Data, you will get a property node, keep that at the start of the code and create a constant. You can also go to the VI properties and>Execution and select "Clear Indicators when called".
I would recommend you to go through LabVIEW basic materials which will give you an understanding about the basics concepts/components of LabVIEW.
(3,613 Views)
I will definately make the time to go through the basic materials. Thank you for yuor help!
(3,607 Views)
