How do I set up IP addresses of users to a remote panel using LabVIEW??
I want LabVIEW to store IP address and the give access to a user once they have requested use of the VI, but only if they have the correct IP address!
(2,673 Views)
Tools>>>Options
Select VI Server: TCP/IP Acess.
Add their IP.
Ben
(2,673 Views)
Ben's answer is correct if you are using VI Server to access and control the VI.
If you are using Remote Front Panels then you want to look at the options for Web Server (still under Tools>Options). Under Web Server>Browser Access you can give specific IP Addresses the right to view a VI or the right to view and control a VI.
Carl L
(2,673 Views)
