How do I set up a While Loop that will execute for a precise number of minutes?
I am relatively new to LabVIEW and wondered what function / structure I should use to execute a section code for a pre selected number of minutes.
I need to create some software that reads data via the serial port of an Infusion device. I have set up the read/write section but without any time parameters. I want the user to be able to select the length of the test which will normally be 1-2 hours and so I need the read/write code to execute for exactly this time period.  At the moment it is in a normal Do While loop and executes until I press the stop button.
Any advice would be greatfully received 🙂
(3,233 Views)
Hi lizimunro
after read and write your data you can check the actual run time and compare with defined run time. see attached example.
Mike
(3,214 Views)
You could use the elapsed time express vi. I have attached a simple VI which shows the operation.
Have fun!
Message Edited by Kabul on 02-14-2008 12:15 PM
(3,208 Views)
Thanks, I will try and see if checking the time at the end works. I did try the elapsed time function within the loop but I wanted it to countdown constantly on the front panel and I guess because I was reading and writing it was going slow and only updated the front panel every so often. It also seemed to run for several seconds longer than I had specified.
Of course it could just be me!
(3,201 Views)
