How do I show an hourglass to indicate wait?
(4,555 Views)
One way is an API call. NI has an example of that. If you do a search for "hourglass" in their example program database, you should find it. Another way is in the attached file. This method I got from the LabVIEW version of the TestStand run-time user interface. It's in LabVIEW 6.
(4,555 Views)
This looks good. Thank you Dennis.
(4,555 Views)
> LabVIEW 6.
> hourglass_display.llb Type: LabVIEW VI Library (application/x-unknown-content-type-LabVIEWLibrary)
> Encoding: base64
> Description: Hourglass Display
This llb won't work when it's really busy. The change must be made in system level.
Any simulation in LabVIE
W will fail. NI's version won't work either. This thread has
been discussed on Info-LabVIEW before. Check the record.
George Zou
http://george-zou.sinacity.com
(4,555 Views)
Hi Dennis,
Do you know if it works in LV5.1?
Sergio.
> LabVIEW 6.
> hourglass_display.llb Type: unspecified type (application/octet-stream)
> Encoding: base64
Sergio Ricardo Pereira Perillo
MSc. em Engenharia Nuclear
Instituto de Pesquisas Energéticas e Nucleares IPEN-CNEN/SP
Área de Monitoração e Diagnóstico
Travessa R, 400 Cidade Universitária
São Paulo-SP
CEP:05508-900
Brasil
Fax: +5511 3816-9432
Telefone: +5511 3816-9164
(4,555 Views)
