How do I size teh group area oin teh mixed signal graph to fit my signal names?
I have a simple mixed signal graph and I have programmed my signal names and they are longer than the width of the existing group pane on the object and I want them to be visible.  How can I resize the graph panes after I write the names to the object?  I know I can customize the thing, but is there a method or property that I am missing here?
(2,785 Views)
Accepted by topic author id
It looks like this is a known problem. You can change the legend size using a property node for waveform graphs and charts, but not for a mixed signal graph.  A good work around would be to mouse-over the grey bar between the legend and the plot area until your cursor changes to the resize tool.  You can then size it to be large enough to show the whole legend.  This is an issue that is set to be resolved in future versions of LabVIEW.
(2,765 Views)
