How do I specify a timeout period for an ODBC connection ?
A picture of the diagram that I used to set a timeout for an ODBC connection and the error I get when I run in are shown in the attached picture. I have used this wiring successfully in previous versions ???
(2,888 Views)
Have you tried specifying the timeout at the beginning when you open your connection? There is a terminal input on Open DB Connection.vi, which is a part of the Database Connectivity Toolset.
Jeremy L.
Jeremy L.
(2,888 Views)
Thanks.
(2,888 Views)
