How do I specify a user font name in Linux?
I'm moving a vi from Windows to Linux. One element of the vi is a user defined font. In Windows the name "Helvetica" is being used. How do I specify a valid font name in Linux?
(2,759 Views)
You may have to install the font of your choice on the linux machine. Once it is installed, you can specify the font for a control, indicator, etc. by using the 'text settings' option in the tool bar.
Using VI Server, you might be able to do a mass change of the fonts for labels and captions. The following webpage contains an example that changes the value of controls -- you could modify this example to modify the fonts:
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/56685792886a556e86256740007fe32a?OpenDocument
I did not thoroughly test this so this option might not be 100% snag free....
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,759 Views)
