How do I specify inverse unit labels?
   How can I apply inverse units, (or even to be even more general, units to any exponential power) to a control or indicator?  ie.    1/mm,   nm^2,   V^2/s.
    I'm  using unit labels for the interface, and doing the calculations on the block diagram, but I can't verify the result because the units don't seem to mean anything.  Something that's supposed to give me 1/mm is giving dpt for example..
NI Hardware: PXI-7853R, PCI-5122, PCI-6733, PXI-1036, PCI-MIO-16E-4, PCI-6110
Computer Hardware: Xeon Quad Core - 2.33 Ghz, 8 GB RAM
Software: Labview 2009, Labview FPGA 2009, Vista 64-bit, MAX 4.6, DAQmx 9.0, NI-SCOPE 3.5
(3,183 Views)
Drop the 1.  Just /mm or /nm^2.  You can also use negative exponents mm^-1, nm^-2.
(3,171 Views)
