How do I stop excel from opening when I run the following code?
I am writing code that modifies an existing excel sheet however, it opens excel file every time I run the code.  I just want to modify the excel sheet without opening it
Message 1 of 22
(4,142 Views)
You don't need to make Excel visible to edit a worksheet. This property can be set via ActiveX.
Message 2 of 22
(4,133 Views)
Change the 'True' constant wired to the property node that specifies 'Visible' to 'False'.
Joel C
Message 3 of 22
(4,102 Views)
Thanks that worked, however now I want to continue edit the excel sheet without getting the following message:
PSU Test.xls is already open.  Reopening will cause any changes you made to be discarded.  Do you want to reopen PSU Test.xls?
Message 4 of 22
(4,093 Views)
I cannot view your VI since you are LabVIEW 2011, but you are apparently not closing that file.
Message 5 of 22
(4,083 Views)
I have attached 2009 version does that work for you?
Message 6 of 22
(4,079 Views)
I have 8.6
Message 7 of 22
(4,077 Views)
here you go
Message 8 of 22
(4,072 Views)
I don't see anything in your VI that closes the Excel file and shuts down Excel.
Have you looked at  Help -> Examples on how to work with Excel with ActiveX?
Message 9 of 22
(4,063 Views)
I have added a close workbook and quit excel invoke node, but I am still getting messages like these:
Do you want to save changes you made to 'test_2.xlsx'?
Like I mentioned before I want to continue to edit and save the excel sheet without anny pop up message
Message 10 of 22
(4,046 Views)
