How do I stop the pop up message: Do you wish to add the directory ___ to your search path?
...since there were no more replies, I assume that there are only the following two options:
including <foundvi> in the search path, or having the (annoying) pop-up message box;
is that true??
Message 11 of 12
(485 Views)
Hi aschipfl,
Yes, this is true. While this is not a perfect solution, you can also look into LabVIEW project libraries to better organize files. Project libraries also provide a namespace qualifier for VIs which will allow you to see if the VI on your Block Diagram is the one in your library. The links below discuss project libraries in LabVIEW:
https://www.ni.com/docs/en-US/bundle/labview/page/using-libraries-in-labview-projects.html
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHvRCAW&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2vlCAA&l=en-US
Julia P.
Message 12 of 12
(445 Views)
