How do I synchronize two counters?
I am using NI-PCI 6115 & BNC 2120. I want to generate two continuous pulse trains using the CTR-OUT0 and CTR-OUT1. I hope these two pulse trains have exact same rising edges, how can I synchronize these two counters? I attached my program here.
Any suggestion will be greatly appreciated!
Stephen
(3,400 Views)
Stephen,
In order to generate two pulse trains on the two counters of your 6115, then you will need to provide a trigger to start both of these counters simultaneously. The counters on the 6115 are controlled via the DAQ-STC counter/timer chip.
In order to perform these operations you will need to use the more advanced counter/timer VIs in the LabVIEW palettes. I would recommend taking a look at some of the shipping examples, such as Generate Pulse Train (DAQ-STC), in order to get a better understanding of how a single pulse generation works.
Also, please take a look at the following websites to get a little more information as well:
Triggering Multiple Counters with a Single Pulse
http://exchange.ni.com/servlet/Redirect?id=10358279
Using the Hardw
are Start Trigger for Single Pulse Generation
http://zone.ni.com/devzone/conceptd.nsf/webmain/7B2CAD8DD522049386256802007B8B51?opendocument
If you have any other questions then please let us know.
Michael H
(3,399 Views)
I have now the responsibility for this Selectpartner of ours:
At microLEX System the problem has been observed on two systems:
A)
HP Compaq dc-7600 Pentium 4, 3 Ghz dual-core, 1 GB RAM
Windows XP Pro, version 2002 SP 2
LabVIEW 8.2.0, DAQmx 8.3.0 f3
PXI-4461 and PXI-4462 on a PCI to PXI extender (successively).
B)
LabVIEW 8.2.1, DAQmx 8.5.0 f5
PXI-4461 on a PCI to PXI extender.
I notice that the DAQmx version is different. Is it possible that an update in DAQmx has fixed the problem?
Thanks!
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
(3,121 Views)
