How do I translate my application into several languages?
Hello to all,
I just finished my GUI on Labview which is in French. Now I have to translate the texts of my GUI in English, and in Polish.
I have no idea how to do it, I searched but I can't really find anything that can help me to do it.
Can you show me where to explain me with details how I should do it please?
(1,589 Views)
This is a good article to get started - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3QKCAY&l=en-US
Santhosh
Soliton Technologies
(1,583 Views)
caption can be updated programmatically, label cant be updated programmatically
(ASCII Strings)
If you have to translate in a languag which needs non ASCII characters, you have the possibility to use Fonts or Unicode strings
Fonts might be easy to use, but usually can handle only one specific language.
LabView Unicode used to be tricky, but contains almost all languagues you'll ever need.
(1,537 Views)
While you can definitely write your own localization support library in pure LabVIEW, it's a tedious task to do. It may be interesting to look into existing solutions, and even the ones which cost some money are worth that money more than once, even if you only ever want to localize a single application. Writing the library yourself is many hours of coding, and there will be always corner cases that will need extra tweaking as you add new controls to your front panels.
https://www.ni.com/en-us/shop/product/localization-toolkit-for-labview.html
https://www.vipm.io/package/jki_simple_localization/
https://www.vipm.io/package/sea_lib_ltk/ (same as first but through VIPM)
https://lavag.org/topic/11216-cr-passa-mak/
Rolf Kalbermatter  My Blog
(1,530 Views)
Helo to all,
Happy new year 2023,
Thanks for all your answers, i will test them one by one and come back to you
Thanks you very much all
(1,437 Views)
