10-13-2005 08:55 PM
10-14-2005 05:15 PM
10-14-2005 05:17 PM
Also, if you have the space on the computer, both LabVIEW 6.1 and 7.1 can be installed simultaneously without any issues. They play nice together (or don't play at all, depending on how you look at it). However, a fresh installation can also be very beneficial.
Andy F.
10-16-2005 01:27 PM
I first tried thru the control panel Add/Remove Programs. No luck. I then tried using msiblast.exe. No luck. I then brought the LV6.1 CD set from my new employer home and was able to de-install most of the items using the control panel. Then using msiblast.exe, I was able to remove everything else except the MS Report Generation Toolkit. I finally used the Windows Install Cleanup utililty msicuu.exe to eliminate that resilient toolkit.
After that, I deleted everything on the hard-drive that was left. Then I went into the registery and deleted the considerable left-overs there. In my opinion, when I upgraded to the Windows Installer 3.1 (Win XP Pro), I sealed my fate in trying to un-install LV6.1.
Now however, I have a perfectly clean LV7.1 install and am looking forward to learning the new features. Thanks!
