How do I uninstall NI-VISA?
I need to use a HP-IB board with labview. In order to get it to work, I need to uninstall NI-VISA and install HP-VISA. How do I uninstall NI-VISA? Also where can I find HP-VISA to install?
(13,465 Views)
You have to go to Add/Remove Programs. Depending on the version you've installed, it'll either have a separate entry or you'll select the entry called NI Software. You'll also have to uninstall NI-488.
I would think that the HP-VISA would come with an installation CD that came with the card. If you don't have it, check HP's or Agilent's web site.
(13,465 Views)
There is no entry in the Add/Remove programs section that mentions anything about NI software or visa.
(13,465 Views)
There is no need to uninstall NI-VISA. You have two options.
1) Just install Agilent VISA (Agilent, not HP has the VISA). Just doing the install in the normal mode will blow away NI-VISA. But that's not the "friendly" way.
2) Install Agilent VISA using the "Side-by-side" option. This leaves NI-VISA as the VISA in control, but lets Agilent VISA configure the Agilent/HP cards.
Look for the "HP" VISA from Agilent.
Once you install Agilent VISA in the side-by-side mode, use Agilent IO Libraries > Conf to configure the Agilent cards. (This may happen automatically.)
You may also need to turn on Passport with NI-MAX to get some things to work. Once you have Agilent VISA installed, its help files give a fairly good description of the process.
Les.Hammer
@CompleteTest.com
(13,465 Views)
Then it would appear that you never installed it.
(13,465 Views)
I have installed NI-VISA Config 15.0 and discovered that it is not supported by LabVIEW 2011 which I am using. I need NI-VISA Config 14.0.02 instead, I think.
I have moved all NI VISA files from the Applications folder to the Trash and installed NI-VISA Config 14.0.02 but when I open it, NI-VISA Config 15.0 keeps appearing and warning about missing files.
Any tips on getting rid of NI-VISA Config 15.0?
(11,214 Views)
Why would you hijack a twelve year old thread? Please start a new one and detail the steps you took. Hopefully, you did something better than just moving/deleting the files.
(11,208 Views)
