How do I update HMI OS?
I have a TPC-2012 with Window CE 5. I'd like to install Windows XP Embedded on it. Does anyone know if it's possible? How can I do this? Thanks in advance.
My regards,
Vinicius
(3,751 Views)
This is the data for your NI TPC-2012
Processor............................................. 500 MHz GX3 LX800
Memory............................................... 256 MB DDR SDRAM
Storage................................................ 128 MB CompactFlash
I/O ports
10/100BaseT Ethernet.................... 1
Hi-Speed USB ................................. 2
RS232.............................................. 3
RS485.............................................. 1
PS/2 keyboard/mouse .................... 1
OS .................................................... Windows CE.NET 5.0
This is the data for the NI TPC-2512
Memory............................................... 512 MB DDR SDRAM
Storage................................................ 4 GB CompactFlash
I/O ports
10/100BASE-T Ethernet.................. 1
OS .................................................... Windows XP Embedded
You can not install XP unless you insert more SDRAM and a new and bigger flash drive. I do not know if the 2012 support 4 GB flash drive. Perhaps it is doable, But it will take some time and money. Perhaps you should buy a new 2512. Given the time it will take and the investment, I guess you will be better of with a new HMI. But if you feel for it, just do it 😉
Message Edited by t06afre on 01-30-2009 11:24 PM
Message Edited by t06afre on 01-30-2009 11:27 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,738 Views)
Hi t06afre. Thanks for your answer. I'll think about an alternative. I'll post an answer about this.
My regards,
Vinicius
Message Edited by falseth on 02-03-2009 09:16 AM
(3,691 Views)
