How do I use Accelerometer readings of myRIO as a shared variable in the FPGA vi
Hi all. I am doing a project using the accelerometer of myrio to equalize the audio output of the myrio. However currently I am facing a problem of using the accelerometer readings as a shared variable in the FPGA vi. Any advice on this?
(3,308 Views)
Shared Variables don't work on the FPGA.  You probably want to use a DMA FIFO to pass the data from your FPGA to the RT for processing.
(3,292 Views)
Any advice on how to do that? I am rather new to LabVIEW.
(3,282 Views)
any help?
(3,244 Views)
Yes please,
I also have this query.
Can someone help with this?
(3,184 Views)
Hi clank and doe,
just examine the example projects coming with LabVIEW. They explain how to transfer data from/to FPGA!
(3,181 Views)
