How do I use Visual basic forms from a labview VI
Can I make visual basic forms (.frm) that can be called and used by Labview?
Is there a way to export data from labview to an active X control or a VB application.
(2,870 Views)
> Labview?
No! You can make Active X components in Visual Basic though and call
them through the LabVIEW Active X nodes.
> VB application.
Well, not as Active X control. However you can either connect the
LabVIEW application as Automation server (A subset of what you can do
through VI Server is then available as Active X methods and properties.
Or you can create a DLL form your VIs with the LabVIEW Application
Builder and call that DLL from VB or any other application which can
call DLLs.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,870 Views)
