Well I've had alook into this for you and I'm not quite sure I understand what you are looking for.
Is it possible for you to phone back in to support?
The reason you are seeing bounce at high speeds, or indeed loss of points, is due to the sampling rate that you have set up.
What you will find is that the trigger will start an aquisition of a number of points at a certain rate. If your sampling rate is too low then you will not finish that sample batch before the next set of samples is recorded.
It is possible to use an external clock into a trigger or digital line, however this will limit the number of samples you can take to the speed of your encoder.
If you increase your sampling rates, and then configure a start trigger from a single input from the encoder you will be able to record a number of samples after a rising/falling edge. (Set the clock as an internal clock)
Hope this helps
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
