How do I use and create run-time menus?
I have a bunch of VI's that I want to be able to access through a run-time menu. I guess I'm just not sure how to get started and what the capabilities of run-time menus are.
(2,520 Views)
You can get started by looking in the on-line help - do a search of menus and you'll find the steps you need to take to create run-time menus. Also, if you do a search of menus in the Find Examples, you'll find several implementations that you can use as a starting point.
(2,520 Views)
