How do I use arrays and double precision constants in the formula node?
How would I use the formula node to include both double precision constant inputs and array inputs to output a new array?
For example, in the Formula Express VI, if I wanted to take the array A = [1 2 3] and square each element and multiply by the constant C = 2, I would write, "A**2*C", including both A and C as inputs into the VI.
I would like to be able to do the same thing using the formula node, but it seems a little more complex. If A was a constant, I would just write, "pow(A,2)*C", but since A is actually an array I'm thinking I may need to create a loop?
(2,924 Views)
Please stick to your original post.
(2,913 Views)
