How do I use dial up (PPP) TCP/IP port on a machine which also has TCP/IP LAN
On a machine which has both LAN and dial up TCP/IP, the TCP/IP VIs seem to use the LAN by default. Is there any way I can use the dial up adapter TCP/IP adapter
(3,084 Views)
I think this depends on the configuration of your Computer. The IP-Stack
normally choses the "best" way itselfe by looking in the routing table.
You probably have to delete the default-route (which often pints to the
LAN interface) to get what you want... but this really depends on what
you want...
bye
Marco
(3,084 Views)
YOu might also want to install the "internet sharing", which forces both ports to be operational.
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,084 Views)
Eric P. Nichols
P.O. Box 56235
(3,084 Views)
