How do I use superscript formatting with an axis label?
If this is not available, can a development request be submitted to allow for sub-scripting and super-scripting.
Message 1 of 10
(6,594 Views)
This feature is currently not available in LabIVEW. Please feel free to submit your feedback in the Product Suggestion Center.
Eli S.
Message 2 of 10
(6,562 Views)
You could fake it, see my example below.  Type the text you want to appear as superscript in the SuperScript String Control.
Message 3 of 10
(6,552 Views)
Also remember that certain things are available as "fake" superscripts as part of the normal fonts.
ABCª CDE° FGH² IJK³ LMN¹ OPQº
I use the "square" all the time. 😉
Message 4 of 10
(6,546 Views)
This is a good workaround for a single placement. II'll use this for a superscript of 1/2 instead of sqrt(Hz).
I would like to replace the scientific notation 1E+3 with 1x10^3 where ^3 is a superscript for each label.
I could do the same if the axis labels were fixed, but with autoscaling, they will change.
Thanks. I'll use the small text placement for one of the workarounds.
Message 5 of 10
(6,530 Views)
Hi, Altenbach,
I hope you are still on the forum.
I need to do a supercript for power of 2 in axis label.
Where can I find the fake script like you showed?
thanks.
Tim
Message 6 of 10
(5,957 Views)
You could just copy/paste from my post above! 😄
(Alternatively, under windows run "charmap" browse the fonts, and pick the character you want)
Message 7 of 10
(5,949 Views)
thanks.
charmap works, but not on every system.
but it works on the one I need to have the superscript.  🙂
Message 8 of 10
(5,938 Views)
You can also simply place a temporary string control, indicator, or diagram constant, right-click...set ot to \-codes, enter "\B2", set it back to normal display and cut/paste the resulting text.
... there are a few more ways..... 😄
Message 9 of 10
(5,925 Views)
great idea, thanks again..  🙂
Message 10 of 10
(5,910 Views)
