How do I use the High Speed Data Logger with multiple I/O devices?
I am using the High Speed Data Logger vi to read from a 16 channel A/D card (NI PCI-MIO-16E). The project may require more than 16 channels. How can I use High Speed Data Logger to read from two A/D cards? Will it be able to write the data to one file?
(2,544 Views)
The High Speed Data Logger vi will not acquire and right to multiple DAQ boards at the same time without modification. LabVIEW is more than capable of doing this what you are trying to do, but you will have to modify the code.
Anuj D.
(2,531 Views)
