How do I use the Index Values property node with a multidimensional array.
I am using a 2D array to store operator inputs on my front panel.  I only want to display one element to the operator at a time.  I am trying to use the Index Values property node to change the displayed element.  However, I can only get the Rows index to work.  How do I direct the Columns index as well?  The help says to use one per dimension.  I need clarification on what this is talking about.  I've tried adding a second element to the property node, 2 seperate property nodes, and diferent wiring techniques. (series, parallel)
(5,130 Views)
If you only wire up one of the inputs (col or row) what you get out is a 1D array of either the column or row. If you wire controls to both, then you will get one element out of the array. Getting a single element in a 2D array requires you to specify both a row and column.
Message Edited by Dennis Knutson on 02-08-2007 08:34 AM
(5,124 Views)
Seems straightforward enough... Let's see if this attachment works.
Randy
(5,109 Views)
You're right. He was asking about the IndexVals property node. Not the Index function. To show just one element though, you also have wite a 1 to NumCols and NumRows but since the user can't resize the array at run-time, I'm not sure what the whole point is now.
(5,098 Views)
