How do I use win32 dll function within my cin code
I was using labview to develop a measuring project.I created a standard cin code which was loaded into code node to complete data analyse task.Within cin code,I used several win32 dll functions,the program crashed.I felt confused.
(2,908 Views)
Sunny,
You need to submit this to NI with details. This is a very complicated task. We have had some experience in this realm, but can only suggest that you talk with NI about this.
The only other thing I can suggest is to use a dll instead of a CIN node. If you do, be sure that all of your code is thread safe (dll's by default use the UI thread, a very bad thing when embedding dlls in dlls.)
Good luck
(2,908 Views)
You should try to build your CIN with debugging information, and if this
proves difficult, build a DLL instead. Then place a breakpoint inside
your source code and call it from LV. This allows you to track down the
crash. I do not see anything obviously wrong in your code, but I didn't
make a proof that it is correct either. That is what debuggers are for.
Greg McKaskle
(2,908 Views)
