How do I vary the voltage of a DC power source using a sine wave on LabVIEW?
Hello all!  I have a GW Instek PST-3202 DC programmable power source.  I want to test the temperature resolution based on voltage fluctuations of my power source.  I've begun writing a VI for this, but I don't know how to fluctuate the voltage in a sine wave pattern.  I found the Sine Wfm function under Signal Processing, but I don't know how to change the "1D array of double" which is the waveform to "sink of double", which is where I apply the waveform to the voltage of power supply.  The VI is attached.
(2,857 Views)
Accepted by topic author airic001
The Format Value function will not accept an array so put it inside a loop. Use a shift register to append all the values from the array to the string.
Lynn
(2,840 Views)
