How do I write to the same control from different frame in a sequence?
(2,585 Views)
There are two ways of doing this in LabVIEW. One is to use a property node for the control and set the VALUE parameter. Set it to All Write first because default is All Read (indicators). The other way of doing it is to use a local variable. I attached a simple example that shows how it works in a sequence. Hope this helps. /Mikael
(2,585 Views)
First of all, try to avoid, at all costs, using multi-frame sequences. These hide code. Alternatively, each frame should ideally be a subVI. In this case, the control/indicator can be written to by using, as suggested, either locals or control references. The method depends on the application.
(2,585 Views)
